No dome, gauge or temp control lights
Old 02-02-2014 | 05:23 AM
000_3500's Avatar
Hi,
No dome, gauge or temp control lights. Every thing else works.
I have checked every fuse with a meter nothing. Could it be the headlight switch?
It's driving me nuts
Old 02-02-2014 | 02:39 PM
wiskeyVI's Avatar
I lost all my gauges, lights, overhead, sect, the weekend after I paid off the truck.
A friend said it may be a cold issue as we had another very cold spell.
That evening after work, everything came back up and functioned fine.
Even w/o the gauges sect, it ran fine.
Old 02-02-2014 | 05:09 PM
000_3500's Avatar
We have had a cold snap but it's past now... I just odd that it's just the 3 things gone out..
Old 02-02-2014 | 05:41 PM
madhat's Avatar
Administrator/Jarhead
It does sound like the dimmer switch. Maybe you could pull the assembly and put a jumpper across the leads to make sure.
Old 02-02-2014 | 08:03 PM
000_3500's Avatar
I'm gonna try a switch out of my buddy's truck tomorrow. I'll keep u posted
Old 02-04-2014 | 06:29 PM
000_3500's Avatar
It's not the switch. Checked what grounds I could see..
Not sure what else to look for.
Old 02-09-2014 | 07:29 PM
000_3500's Avatar
No voltage going to the dome light...
Old 02-10-2014 | 08:53 AM
KWKING's Avatar
You've checked all your fuses I presume?
Its a long shot, but have you looked at your wiring under the hood. I have had a mouse chewing on my wires this winter.
Also what yr is your truck?
Old 02-10-2014 | 09:39 AM
000_3500's Avatar
I have check all the fuses (in the box driver side under the hood) Im guessing that's it for fuses..
No I haven't looked at the wires under it..
The truck is an 06. It does have a factory remote start. not sure if that would have anything to do with it.
Old 02-10-2014 | 10:31 AM
KWKING's Avatar
It could be fuse #35 CCN, cabin control nodes , a 15 amp blue fuse and maybe check for 12 volts on pin 1 of the light sw assembly a white wire with a light green tracer
Old 02-10-2014 | 11:05 AM
000_3500's Avatar
ok thanks. Il have a look tonight.
Old 02-12-2014 | 02:35 PM
000_3500's Avatar
Fuse 35 was fine.
Checked for voltage at the plug. Didn't get anything on either wire!
I had one lead right on - battery and the other I used to test. Never got a thing.
But yet there has to be something there because the radio lights work...
So odd
307Kenworth
02-23-2016 05:37 PM
DodgeRamdiese01
07-30-2010 07:15 AM
larry30000
02-26-2006 06:29 PM
ryan77
07-29-2003 10:31 AM
Lil Red
06-06-2003 11:07 PM
Quick Reply: No dome, gauge or temp control lights
