No blinker
Old 12-20-2007, 07:41 PM
1st Generation Admin
BC847's Avatar
Talking
I can't believe that even with all the hi-tech diagnostics on these trucks, folks continue to fail to check the basics.
Has anybody checked the Blinker Fluid as high bid suggested above?
Duh ! ?
When mine run slow, I always fill-up with this stuff. Seems to work OK ~ http://kalecoauto.com/index.php?main...&products_id=6
Hope this helps.
Old 12-21-2007, 01:21 AM
DTR Founder
jthorpe's Avatar
Originally Posted by motormouse
Not a urgent emergency but i have to leave tomorrow for a wedding and need to drive into city.
Then it doesn't qualify to be in the section originally posted. Moved to appropriate section..
Old 12-21-2007, 08:32 AM
tbarbee1's Avatar
Well i finally got the dealer. They told me my plow setup wiring triggered a code and shut down power to the blinker. I sliced in the blinker wire for the headlight module on a Meyer's. They said that it may do it again so i'm not sure what caused it and how i can prevent it?
I had the same problem when I replaced the factory bed with a flat bed having more lights. The additional lights pulled more amps than the factory setup so the computer saw it as a short and turned off the circut to avoid burning things up. "Seems kind of redundant I thought that was what fuses were for." Anyhow the dealer changed the computer to let it runs the lights and not see them as a short. This could also be your problem if the plow has additional lights or if it is using the circut to draw any power above what the factory lights would pull.
CORed
31
03-30-2007 12:13 PM
ekim440
06-10-2006 05:53 AM
BigBlue
16
05-02-2006 12:41 AM
dodgedude361
08-22-2005 07:57 PM
mikmaze
02-13-2005 12:23 PM
Quick Reply: No blinker
