New Exhaust Time
Old 07-11-2012 | 01:40 AM
napa169's Avatar
New Exhaust Time
The pipe has broken off right at the front of the muffler.
When something like that happens, it is generally a good time to go new and spend money once, rather than twice - the repair and then the new system...
After my research, the two things that stick out for me for 2003 Quad Cab Short Box 4x4 are:
51" Donaldson muffler - $97.65
FTE Resonator - $109.75
Now for the rest of the piping. I have looked a see that there are full kits but is that what I need and then just cut them up? Can/should I buy the individual pieces? If so, where?
What would you do? Links etc would be appreciated. (Referrals, less expensive etc etc) lol
Old 07-17-2012 | 11:38 AM
surfram's Avatar
I have been happy with my stainless magnaflow 4" turbo-back.
http://www.summitracing.com/parts/MPE-17974/
Old 07-18-2012 | 07:48 PM
kerry.king's Avatar
I have a flo pro 4" tbe and love it. super quiet, no drone...
After an 01 24 valve that I straight piped I had to have quiet. This is super quiet.
Old 07-20-2012 | 01:03 AM
alboy's Avatar
I have the Fte resonator up front 4inch, Magnaflow 4x30 straight thru, happy with it, no drone at all as i pull a 36 ft fiver. Had a flo pro twister , threw it away,way too restrictive towing with a tuner,high EGTS.I like what your thinking,youll be happy with it,The fte res does a great job.
Old 07-21-2012 | 09:28 PM
hump's Avatar
Flo Pro Twister...
alboy....Why do you say the Flo Pro Twister race muffler is too restrictive? It's the same design as the FTE resonator. Both mufflers have a small center straight through design surrounded by an outer corkscrew. Just curious as to why you say it's more restrictive?
Old 07-22-2012 | 07:58 PM
alboy's Avatar
hump ,The flo pro i had installed looks like a regular muffler with an offset inlet outlet with a curved inside with tabs sticking into the exhaust flow.I tow a 15000 lb fiver and could not keep egts acceptable pulling a 6% grade, made the change, no more problem.
Old 07-22-2012 | 08:01 PM
alboy's Avatar
Looked it up flo pro max, not impressed for my application, spool up is a way faster now and egts are fine.
Old 07-24-2012 | 12:26 AM
hump's Avatar
Now I got it....I'm running the Flo Pro Twister race muffler which is identical to FTE's "resonator" muffler. I actually thought the FTE's muffler was a little more quiet than the Flo Pro Twister.....
Badd Dogg Guy19
09-12-2015 11:04 PM
dj_souvlaki
14
10-16-2007 08:24 PM
taken5875
20
01-11-2007 10:38 PM
