Navigation Antenna Question Please
I am in the process of switching radios into my new truck and after connecting everything up with the navigation radio the screen says "GPS Antenna is Disconnected"... it's a factory system. I pulled it back out to verify it was plugged in firmly and still the same thing. I am assuming the antenna is now bad or am I missing something somewhere? If the antenna is bad does anyone know where a replacement can be found on a Sunday? Thanks in advance for any responses-
Look under the right front kick panel. That's where the GPS antenna connects to an extension cable.
The SMA connectors are also quite delicate. Check for a bent center pin.
Tony
Tony
What year truck? I have installed/removed numerous factory NAV systems in 03-08 trucks and never saw any type of "Extension" cable. I also never had the issue you are describing so I'm thinking you have a bad antenna wire. Maybe it's just kinked somewhere. Where did you mount your antenna?
03RAMBUNCTIOUS
63
08-12-2009 12:16 PM
turbosonoma
12-18-2006 09:05 PM
Justwannabeme
12-17-2006 12:29 AM
Reel Native
06-10-2006 10:14 PM
t-15 firefighter
12-05-2004 07:23 PM
