Muffler? I don't need no stinking muffler!
Old 10-13-2007 | 04:06 PM
BMH95's Avatar
I took the muffler off today. Like everyone says, the muffler is a bear to get off. I used a dremel and three cuttoff wheels to slit the sides of the muffler pipe, then pealed them up / down and got the dang anchor to fall on my hand and nearly smash it flat. Note: Watch out for falling muffler!! The hangers are a pain for sure, and are your biggest ememy. I had to push pull curse and fight with it before I figured out the rear most hangar was the one causing all the trouble. Once I adjust that one, it came off ok. Putting the new pipe on took some more hangar manipulation, but it was a lot easier than the anchor removal. Once I got it all clamped down and the hangar on, I took it for a spin. I like the sound a lot. It sounds like a Freightliner when you want it too, but just adds a low rumble under normal driving. It did have a NASTY drone at first, everywhere. I loosened the hangar and moved it to a more comfortable looser position then clamped it down TIGHT. I also torqued the band clamps down TIGHT with an impact. The drone is now gone, and the sound is incredible. My buddy just bought a stainless 5 inch complete, so when he gets that on I'm curious who's will sound better.
Highly recommend it (Genos eliminator kit, with 4 inch stepped band clamps from the local International shop).
Old 10-16-2007 | 10:09 AM
BMH95's Avatar
wow, I thought this would be interesting for some
shows to go ya
Old 10-16-2007 | 10:31 AM
Swayse's Avatar
Lots of strait pipe dodges around here, less drone than an aftermarket strait through muffler. But, way too loud for me, so mine is stock with cat busted out and the tail pipe cut after the axle.
Old 10-16-2007 | 11:02 AM
2171CTD's Avatar
Im about to order the Genos kit for my 06. Did it come with all the hardware or did you need to buy anything seperate?
Old 10-16-2007 | 11:47 AM
BMH95's Avatar
It only comes withe the pipe and the hangar. I think it says to reuse the factory clamps, but mine were rusted so badly I had to use an impact to get the nuts off the threads, or I would have been fighting with a rachet for 10 minutes. The impact worked hard all the way to the end of the threads. I got two band clamps from the local big truck shop that cost me $25 for the pair.
Old 10-16-2007 | 11:48 AM
BMH95's Avatar
I left my cat on, so it's really not very loud unless you give it some go pedal.
Old 10-16-2007 | 01:38 PM
Dieseljunkie's Avatar
I cut out the muffler on mine a long time ago, and its great. A lot of the time though, I don't think its loud enough.
Scott
Old 10-16-2007 | 03:49 PM
LFD2037's Avatar
I'd like to get rid of the muffler, too, but am scared of the drone, especially on long road trips w/ the TT behind me. Does it drone when pulling a trailer? I also wonder if it would be any louder than it is now w/ the Donaldson 40"?
Old 10-16-2007 | 04:59 PM
BMH95's Avatar
I haven't towed with it yet, so I'm not sure about the drone while towing issue. I will tell you that it is not noticable at 65 - 70 mph on the highway. You really can't hear it at all, it sounds like it did with the muffler at those speeds. I have read many times that the cat quiets it down significantly, that's why I left mine on.
Old 10-16-2007 | 06:19 PM
jtrimmell's Avatar
That was the first thing I did to my truck the week I got it. I had a straight pipe put in and I left the cat but I had horrible drone. I havnt heard any straight pipes yet with no drone. I still have my cat with my 5" Bully Dog Exhaust and its pretty loud still. With out the cat was unbearable. The cat deffinetly quiets down the straight pipes.
Old 10-16-2007 | 07:00 PM
LFD2037's Avatar
jtrimmell, Your saying w/ the cat, there's no drone?
Old 10-16-2007 | 08:14 PM
Mine doesn't drone too bad when towing, but the biggest thing I tow is my flat bed 24' car trailer with a jeep on it.
Scott
Old 10-16-2007 | 08:34 PM
jtrimmell's Avatar
No I had a horrible drone with the straight pipe and my cat still in. I drove 1700 miles in day and a half and grew to hate the straight pipe at 80-85. With the bully dog exhaust I had alot of drone with not cat. But that lasted about two days and it went right back in the shop and I had the cat put into the 5" System. The cat does help with the drone though atleast IMO.
Old 10-16-2007 | 10:59 PM
kokalit's Avatar
Unloaded mine sounds great. But pulling a 5-6K TT (plus 600-800 Lbs in bed) to Ohio and back this past summer, had significant drone. Didn't bother me or Bassett hounds much, but gave the wife terrible migraines. Looking at getting a Donaldson to put on when towing long distances. My 4" band clamps will make swapping out for a trip relatively painless.
