Module-Totally Integrated Power Question
I asked for and received (THANKS Grant) a wiring diagram for my 2006 3500 Dually.
I learned that the embossed fuse labeling on the lid of the fuse box can be misleading. The wiring diagram helps with, among other things, the terminology for the circuits.
My "Fused Park Lamp Feed" (8W-13-11) keeps blowing fuses.
Every light on this feed is inoperative.
Thought it was the plug going to left tail running lights. Changed the plug out,
@ 33.00 for the factory part. The prior owner had installed LED lights in line at the plug, so it was suspect. Tried swapping out the tail light circuit board, no luck.
Has anyone had any experience with the "Module-Totally Integrated Power".?
Is there a way to test the output for just one feed?
Where is this magic box located?
Thanks in advance to all.
Bob
Bob
Tipm
Your 2006 truck was the first year for many changes to the power distribution and module communication. The Totally Integrated Power Module (TIPM) is located in the same "box" under the fuses. The fuses are the top of the TIPM.
I found the short.
Knowing where this TIPM is helps for the future.
RJ
vrj
12-12-2014 01:30 AM
Jeff in TD
12-25-2009 11:03 PM
Pride & Joy
01-20-2007 09:10 AM
