Mega cab window crack
Just found my left rear mega window cracked. No apparent reason for this, sitting in garage. 5,000 miles. Do ya'll know if the dealer will warranty this without any smack? Any knowledge would be appreciated before I contact dealer tomorrow. Thanks
I just had my front drivers side repaired. This is the explaination I got on the cracking windows. DC put in a new laminate window, it is slightly thicker than the glass window. However, they did not modify the hardware causing the crack, it was replaced under warranty with glass. As I was told, DC is debating a recall because there is enough of these to warrent one. It will be for replacing all laminate windows with glass. This information came from my service writer.
Wayne
Wayne
Laminated side glass
I just had a RH front window crack. The dealer said it is rock chipped and the laminated glass cost slightly more than $500.00. I checked aftermarket glass shop, laminated glass $427.00, tempered $103.00, but I was told that the tempered glass would work but the window will rattle in the window track as the tempered glass is approx. 1/16 of an inch thinner than the laminated. 2006 Quad Cab LB DRW 6 Speed 5.9 CTD
Rock chipped? How do you rock chip a side window other than vandalism? That reminds me of the Seinfeld episode where Keith Hernandez spit on Kramer. "this is where the laws of physics cease to exist...the lugey stopped in mid area...went over his shoulder...then turned right into his neck...
After I posted that, I was thinking that rocks could deflect off the mirror. I get bugs all down the side windows from that.
I hope I never have a problem. The laminated glass is one of the reasons it is so much quieter inside an 06. I'd hate having to switch to the tempered glass.
Still wiating
Took mine to the dealer. They took about ten pics and sent to DC. Still waiting, two days already. Dealer claims it is the first they've seen. I'll let ya'll know.
My dealer said it was there first also,they fixed it.Then I had the second crack and they knew there was an issue.I heard it was a vendor problem,If there is a little chip in the edge of the glass it just runs
dockrocker
39
04-24-2011 09:43 PM
jimbo486
13
11-05-2009 09:17 AM
ThirdTry
34
01-14-2008 02:56 PM
jrussell
05-08-2007 09:24 PM
