Master list of starscan options
What I know of....
Hi idle (most already know of it)
Accessory Delay...Allows radio to be played for up to 1hr w/out key
What I've heard of....
Tap the turn signal & it flashes 3x...useful for lane changes
There's gotta be more!
Tony
Tony
On my 2006 you can have day time running lights, your head lights turned on once you put it in gear. BTW, my power on with key off can only stay on for 10 minutes, that was the max time they could set it for and I sure wish it could stay on longer.
that don't sound right my dealer told me mine could be set to stay on forever...until you open the door...mine is set for 15 mins I wish I had had them do it till the door opens
Guest
Posts: n/a
some that i know or had
had a 06/4 speed have a 07/6 speed both 5.9
-high idle auto (manual u need to ground pin #22 on the ecm)
-fog lights on with high beam had this on my 06 they say its no more in Canada
-daytime running lamps (must be on in Canada)
-acc on when key is off until u open the door
their is a set time for this and it can be controlled
-the turn signal thing blinks 3 times when tapped, I have this now
- when you open drivers door they all unlock, very use full
- i believe on some you can lengthen the interior light on time
- have your headlights stay on for a set time after you leave your truck, nice when
their is low lighting
-one setting where i seemed to have to brake lights lol, hod to go back and get this
fixed
thats all I can think of now
fixed
Administrator/Jarhead
I think that if you leave the lights on after you shut the truck off, then turn them off, they will stay on for a minute... like a delay. It does it on my wife's 03 hemi...
Intersting thread. On my 07 5.9 I have the following features:
1. Head lights stay on for a few minutes after shutting off the truck.
2. All doors unlock when you open front drivers door.
3. High Idle, have automatic trans.
4. Tap turn signal and get 3 blinks.
5. Accessories work for 5 or so minutes after turning truck off or till you open door.
I think that is all I actually have that are working now. Trying for another one below.
Taking truck in for service Thursday and will check on fogs with High beams as I drive & live in many very rural areas and deer are very plentiful, have dodged a few in the last 2 weeks.
Help!!!!
Truck is at the dealer for service, and I have asked for the manually controlled High Idle, and they say it cant be done, without 3 hours of labour, wiring, blah blah blah.... It is in my owners manual..."have your dealer activate this feature"
I would like the turn signal feature, and the accessory feature, for the power windows...
I have a 2006 MegaCab, with the Auto, so it should all work, riiiiiight?
Your dealer is dumb and sorely misinformed...yes they can do it and it takes 5 minutes, if that. They may still charge you for it (I paid 50) but its maybe the best 50 bucks Ive spent. I use high idle every single day of the year
Run a search to two, someone on here has pix.
I jumped mine to the parking lights.
