lowering rear of 06
lowering rear of 06
I neen to lower the back of my truck to help level my goose neck. if i raise the truck and put it on blocks can i then losen the u bolts a little so the rear end will drop down an then slide one or two spacers out, with out taking the u bolts all the way off.the threads on my u bolts are long enough so i dont have to put the spacers back on top of the springs.
I removed my leveling kit and lowered rear on mine by swapping the two spacers from bottom to top. Used this link for the process.
http://www.klenger.net/dodge/lowerin...d/slide01.html
EDIT: Just for the record Matt400 over on the TDR was the first to do this rear end lowering procedure that I remember, that's were I picked up the mod, klenger done a good walk through with pics though.
Tony
Seems like I remember that you have to take the u bolts off to get to the spring center bolts. The center bolts go thru the spacer blocks so they have to come out. Look at the Klenger writeup on how to do it.
Lots of good info there. The slide show on lowering the rear is under 3rd gen reference.
nasty01cummims
06-30-2009 01:52 PM
Mike4122KSA
11-08-2006 08:46 PM
ppsi
32
05-15-2004 02:19 PM
