Loss of power steering when turning with brake applied
Old 01-27-2004, 05:41 AM
spots's Avatar
Dodge is rekalling bal jointts on the Dakotta truks. How do u get a new kar to brake then??
Check here http://www.iespell.com/. It will help you out.
Old 01-27-2004, 01:14 PM
Joseph H. Smith's Avatar
I started to notice a steering problem on my truck at about 2 years old. I was having intermittent hard wheel whether moving or not. A year or so later I noticed intermittent stiff brake pedal. Then one day I noticed them both at the same time. I read my manual and found that they both use the power steering pump. From that point as soon as I noticed a stiff wheel I would brake immediately and I found that everytime I had a stiff brake pedal and vice a versa. You don't have to be using them both at the same time. I bought the guages and adapters to hook up to the power steering system but by the time I had enough time to check it out it had stopped. I have not had hard wheel/stiff brake pedal in over a year.
Old 01-27-2004, 06:12 PM
RickE's Avatar
Thanks, Spots. I downloaded and installed the spell checker. It works great!
Old 01-29-2004, 03:46 AM
Teddroe's Avatar
I had an 01 that did the same thing, especially in the winter. I took it in they put a pump on it, they put a gearbox on it, they pressure tested it, they said everything was normal. Nothing helped. So guess what, they said live with it and I did................Your brakes and steering work together off the power steering pump. Diesels don't have vacuum like cars do so the pump is working double duty, twice as hard.
offroadcpa
20
02-18-2020 03:18 PM
RHC
08-12-2019 03:32 PM
cad14man
14
06-30-2004 10:24 PM
Quick Reply: Loss of power steering when turning with brake applied
