Little plastic pipe sticking out of firewall.
Hello from a new Dodge diesel owner. Never had one before, mostly lots of modified jeeps; however, I really dig my 04.5 RAM 2500 5.9L TD and am curious to learn more about diesels and how they run.
Quick question, I have the in-cab oil fumes option on my truck and will extend the blow by tube like others have suggested, added Mopar lemon crankcase scent (useless). I did notice halfway down on the passenger side firewall that there is a black plastic tube (1/2" I.D.) sticking out about 2 inches that seems to have slight water dripping from it. Can someone tell me what this tube is for and could engine fumes be coming in through it into my cab vents? Thanks a bunch.
First time I ever had the AC, parked the truck, and got out, I almost pooped myself when I saw the puddle of liquid under the truck - thought it was coolant or oil. After I saw it was water, opened the hood, and saw it coming from the AC condenser tube.
Originally posted by wexman
Slight? On a hot day, when I have had the AC on, this thing gushes like someone opened the Hoover dam!
Scott
Top's Younger Twin
Hmmm maybe this is where the fumes are pulling into the cab.
I might put a '90' on that with a piece of hose dropping down closer to the street and see if that helps.
Top's Younger Twin
Originally posted by Planetcat
Scotty, you and I are on the same page. Already bought the 90 and tubing for it, but just wanted to make sure that I wasn't going to screw anything important up. Thanks everyone for the info.
Make sure you let folks know.
Theres been a few other efforts to resolve this...one was sealing the cowl and the other was running a hose for the crank case breather to the back fo the truck...none of those worked for me.
Scotty
Same here, sealing the cowl and extended the blow by tube past the rear differential did nothing to cure the smell in the cab when at a stop light,
Finally after 17,000 mile the smell is gone...don't know why, maybe something to do with the engine breaking in.
Ron W.
Ron W.
The level of smell dropped a lot in my truck until my first oil change. Then it was back, but fading away again. I don't know if it was just the mechanic dripping something under the hood that had to burn off or what.
avantidude
08-23-2013 11:58 AM
js091899
10-13-2011 02:07 PM
bluechrome
04-10-2008 09:40 AM
ggades
12-07-2006 12:41 PM
