lights
Gullydog check out WWW.xtralights.com they should have something that interests you.I personally would go with the HID conversion ,and they have it with HI/LOW beam.They have a really good site I feel.If you do find something (somewhere let me know,I`m just comparison shopping right now).
Does or has anyone here tried any of Xtralights products? I am considering trying a set of the Dual Halo projector headlights.Any feedback would be welcome!! Thanks!!
Check with Morkable he is from GP and he had projectors and he really did not like them.If your not doing anything next w/e you should come up to Olds.There should be about 10-12 trucks most will run on the dyno.Morkable says he`ll be there so you could talk to him about his previous lighting issues.
I just put a set in this weekend, I have pics 1/2 way thru with one regular light, and one halo light. I will get it posted up today or Tuesday. I wasn't crazy about the lights after install either, but then I adjusted the beams a bit and I like it now, more light output in lo and hi beam.
I'm really not impressed with the stock headlights either.
The HID kit looks good but is pricey at $500. I would also be concerned that just adding a brighter bulb or system may or may not make things better. I'm no lighting engineer, but from what I've read each light is "tuned" based on it's shape, reflection, etc. etc. So adding more light may in some cases might just make things worse by refracting the light improperly. And in the process having oncoming traffic flashing their brights at you constantly.
My use of words may not be technically correct but you get the idea.
Is there anyone here with a technical background in lights to shed some light....pun intended...
proudpapa97
05-04-2008 06:50 PM
cummins dsl
22
06-27-2005 11:53 AM
MoreSmoke
22
01-10-2005 03:05 AM
CHarlan
08-06-2003 08:40 PM
