Light Switch RR
Light Switch RR
Anyone out there no how to remove the headlight switch panel/bezel from the dash of a 04 2500? Does it simply "pop off"? Thanks in advance.
Administrator/Jarhead
That whole plastic assembly that houses the vent comes out first, then the switch is disconnected from the harness, then unbolt the switch from the plastic piece. Just grab it by a seam and apply steady pressure.
(1) Disconnect and isolate the battery negative
cable.
(2) Remove the left instrument panel bezel. (Refer
to 23 - BODY/INSTRUMENT PANEL/CLUSTER
BEZEL - REMOVAL).
(3) Disconnect the harness connector.
(4) Remove the screws that secure the headlamp
switch to the instrument panel bezel (Fig. 10).
(5) Remove the headlamp switch from the instrument
panel bezel.
INSTALLATION
(1) Position the headlamp switch to the left instrument
panel bezal and secure with screws.Tighten the
screws to 2.2 N·m (20 in. lbs.).
(2) Reconnect the instrument panel wire harness
connector for the headlamp switch.
(3) Position the left instrument panel bezal on to
the instrument panel.
(4) Install the cluster bezel onto the instrument
panel (Fig. 10).
(5) Connect the battery negative cable.
cable.
BEZEL - REMOVAL).
panel bezel.
INSTALLATION
panel (Fig. 10).
You got it, brother. I'm not far from you, if you need help, I'm here for you. All I charge is that you have a beer or three out of my kegerator...
stratos201proxl
01-16-2014 11:04 AM
Joey-D
12-12-2011 12:52 PM
