LED lighting
LED lighting
Since my truck didn't come with any kind of light for under the hood, I'm thinking of adding two rows of led lights. I saw the same thing on another web site I use to belong to many years ago when I owned a Toyota Tacoma.
Planning on removing the hood insulation since its falling down and parts of it is melting from touching the engine. They used the kind that have a sticky side on one side. I'm planning on using the kind that has a metal on the backside and attaching them to the inside hood frames. Do any of you know if I need a fuse between them and the battery? I found a switch to use so the come on when the hood is opened.
That's cool. If you have a truck optioned for it you will have underhood lighting. If not, the plug for power is on the passenger side firewall. I'll have to go take a look. I have always wanted a light under the hood. Holding a flashlight is not fun when you need it at night.
I think mytruck has the harness but no light. It would behelpful. I'm tired of propping up the big spotlight to see what I' doing when in the garage
OP, does your truck have the insulation pad under the hood? If so, how do you plan to attach the lights? That Toyota shows the light strip stuck directly to the underside of the hood.
