I want to repaint my rusty rear axle
Old 05-05-2012 | 04:37 PM
InfernoMega06's Avatar
Hello, all! Does anyone have experience repainting their slightly rusty rear axle? I am starting to research the project. I am looking at using a can of some type of spray paint and just tape off everything I don't want the black paint on.
If you have done this, what exact paint did you use? Also, I would really appreciate any tips and tricks. Thanks in advance for the replies!!
Old 05-05-2012 | 06:12 PM
BigIron70's Avatar
Cummins Guru
You need to neutralize the rust first or you are wasting your time. Rust will come back in short time. I would try somehing like this first. Then you can paint over it without rust coming back.
I used it on my boat engine and it worked really well to stop corrosion from coming back. Worked well on boat trailer also. They sell similiar product at boat stores and hardware stores also.
http://www.eastwood.com/eastwood-rus...st%2BSolutions
Old 05-06-2012 | 12:48 AM
Jeff in TD's Avatar
I just used an aggressive wire brush on a drill, followed by some carb cleaner, and black high temp spray paint. When you are due for a fluid change is a good time to do it.
Old 05-06-2012 | 10:14 AM
Danavilla's Avatar
Although the rust on mine wasn't real bad, it looked like the workers in Mexico had used a broom to dab on the existing paint. I just wire brushed off what I could and hit it with Rustoleum primer followed by a can of their black paint. Several years later and a touch=up or 2 and it still looks better than when new.
Old 05-06-2012 | 10:50 AM
Shorts's Avatar
No deep rust here, just surface so I used a wire brush to knock off everything I could. Then acetone wipe down. Self etch primer (IIRC) and then some Rustoleum black spray paint satin or semi, can't remember). It's holding fine.
I didn't get ocd about this as my intention to clean it up to look a little better than rust. I didn't make anything or get picky.
Old 05-06-2012 | 12:06 PM
Thanks for the info guys! Yep, I'm just looking to cover up a little surface rust. I knew some of you guys had to have painted yours. I just wanted to make sure I was on the right track. I appreciate the replies!
Old 05-06-2012 | 12:14 PM
Shorts's Avatar
I'll grab a photo for you in a little bit of the axle how it looks today. Can't remember exactly when I painted it but its been at least a year, possibly two.
Old 05-06-2012 | 05:45 PM
ChrisJohnson's Avatar
Gonna do a free spin hub swap in about a month, plus change out both differential oils then. Will do the the same with the paint thing, that is if it turns out good for you guys, and/or Shorts pics make it look good, and make it a worth while project! Looking forward to any pics!
Old 05-07-2012 | 04:01 PM
Shorts's Avatar
Here's my superfast halfreared tag job The whole thing looked like the dshaft lol Like I said, no masking just eyeballing.
Old 05-25-2012 | 01:41 AM
http://i1057.photobucket.com/albums/...0524-00220.jpg
http://i1057.photobucket.com/albums/...0524-00221.jpg
I finally got it done! Steel wool, wipe down with micro fiber towel, Rustoleum Rust Reformer black, Rustoleum black satin. I did a lot of taping off and using cut apart garbage bags to keep the black paint off of everything I didn't want black. I may do the sides of the frame you can see in the rear wheel wells next...maybe.
Old 05-25-2012 | 08:56 AM
Shorts's Avatar
Nice!
Old 05-25-2012 | 11:59 AM
Lil Dog's Avatar
Wow.. looks good!
Old 05-25-2012 | 01:26 PM
cstewart's Avatar
Yes Sir...that came out NICE!
Old 05-25-2012 | 10:09 PM
donato's Avatar
I live in AZ so not too much rust here but the paint on the front and rear axle of my 05 was starting to show signs of age.
I started a project to undercoat my whole truck; wheel wells, axles, leaf springs, etc., just about everything that didn't get real hot with that 3M Rubberized Undercoating.
I'm only about half done but so far the project is looking good.
donato.
Old 05-28-2012 | 06:28 PM
Idaho Guy's Avatar
Very nice indeed. Now I'm itching to make mine look a little better. Gee, thanks a lot...
sallyman1
01-10-2015 11:12 PM
snowmanx
05-23-2010 10:18 PM
93-12Smoke
05-04-2009 06:48 PM
asnowsquall
03-15-2009 07:59 PM
manganos
02-25-2006 05:56 PM
