I need a battery trick
Looking to brainstorm this!!!
Ok..I have battery cable connectors that seem to be tightened all the way and yet they aren't tight on the battery posts. Anyone have any ideas how to tighten them further without replacing the posts?
I thought about getting a piece if lead and pounding it real thin and then wrapping it around the battery posts before I put the Connectors on and also putting some Dielectric grease in there...What do you think?
Or anyone have a better suggestion?
They are tightened all the way and are still loose so help me with a trick!!!
I have used copper tubing and slit it length wise (Home depot / Lowes
or even a hobby store.) That way you will retain contact the entire circumfrence of the post. and since it is already round, little or no shaping required.
Penny is a darn good idea....
DTR's 'Go to Guy'
Take a die grinder and grind some of the space between the battery cable end where it comes together. For lack of a better description, here is a crude drawing. You can always open it back up when you replace the battery - so no big deal. NOTE!!! - Don't grind directly over the batteries! Sparks and batteries can be bad!
When you tighten the bolt all the way down you probably have no gap between the clamp. remove the bolt, open the clamp and remove some of the materal that is currently making contact (1/16 each side). Then when you tighten the bolt there will be a space and all clamping force will be on the post not between bolt. ... Oops sorry two guys already beat me to it.
Actually any penny prior to 1982 is copper... well except for the 1943 steel and the rare chance you find one of the aluminum trial pennies made in the 70's.
Good Ideas guys.....I thought about cutting the middle of the clamp out like the diagram shows but when I looked at the bolt it is already at its end of where the head hits the clamp even...That doesnt make much sense how I wrote that. So I was hoping for a plan two.
I wonder if the penny trick would cause any kind of electrolisis.....you know...dissimiliar metals creating a corrosive atmosphere?
I went down to the the local Discount tire and found two lead tire weights on the ground........I hammered them out real nice and thin and they look like they will work. I am glad you guys posted what you did because it lets me know I am on the right track.
Now to read about which batteries are the best.....Optima? Interstate? Auto zone? Walmart?
Love this website....
Good work everyone....
