HVAC blower, high speed only
So I had an issue a few months ago with the blower motor only working on the highest speed. I checked the blower resister and found it to have gotten hot and breaking loose the thermo couple. I soldered it back together temporally and it worked fine till I could get a new one.
I installed a new one from the dealer and all was well again for a couple more months.
This morning it seems to have been overloaded again as the same problem is occurring.
Is there a common issues in the switches somewhere that causes this to happen?
Pretty frustrating when I spend up to 6 hours a day in the truck.
Possibly the fan motor drawing too much current and cooking the resistor......it's just a thought.
When I replace a blown blower resistor, I usually measure the max current draw of the blower motor at the same time. If it's over 18 amps the blower motor gets replaced too. To me, a repetitive resistor failure is pretty good reason to suspect a worn motor.
Current draw is what I test on the blower. I use an amp clamp, and put the clamp around the positive lead to the motor, then read the amps with the blower running on high speed.
torquefan gave the only way to test the motor, the resistance of a bad motor does not usually change enough to tell. motor drag, bind, or armature rub is the most common cause of higher draw.
tom.jelly
11-10-2006 02:04 AM
