how to remove radio bezel in a 06
The picture didn't load so I'll try again. Basically you use a thin tool to pop the clips located around the bezal and pull it out to unplug the wires. It just snaps back in afterward.
Dan
PS
Oh, there's a screw, or place for one, at the bottom of the panel that may require removal of the bottom console, if your's has one. Mine didn't have a screw in it so I only had to pull the console once to discover that.
Dan
PS
That might work but you're better off using a hard plastic tool so you don't scratch the surface. I used a putty knife the first time but bought some Harbor Freight tools made for it after that. Maybe a plastic paint scraper?
Dan
Dan
No need for special tools.
Get ahold of it where you can feel the edge of the trim on the drivers side top left. Just give it a good tug.
Another good spot is if you have the small cubby on the passenger side. Use that for a grip point.
Just make sure that you dont have the screws in place before you go to tugging.
Once you have the screws out, do yourself a favor and leave them out. Makes for easier removal in the future.
soilsample
03-30-2015 09:28 PM
dodgebowhunter
07-21-2008 05:44 PM
wreedCTD
04-25-2007 10:36 AM
