How long do these batteries last?
Old 08-06-2008, 05:12 PM
Beavermike's Avatar
I have an 04 (see sig below). So it's almost 5 years with the original batteries. I usually replace stock batteries at this time, just don't want to trust a 5 year old one during the winter, or when off hunting.
However since these beasts have two, maybe I should just let it go awhile. Or maybe replace one battery. Any thoughts, experience on this? If one goes, will these start ok on the other battery?
Anyone have any experience with these?
Old 08-06-2008, 05:41 PM
FlaCracker's Avatar
Never replace just one battery, always replace both at the same time. If you have gone 5 yrs on the same batteries you are running on borrowed time...I would definitely recommend changing them out. I plan on replacing mine at 4 yrs, if they last that long. When you consider the alternate of being stuck out in no where and having to call a tow truck in the middle of the night...less hassle and save money by being proactive.
Old 08-06-2008, 05:43 PM
MikeyB's Avatar
Still running the originals in mine. The batteries are 6 years old now.
MikeyB
Old 08-06-2008, 05:52 PM
rip 112's Avatar
My batteries are originals also, no problems, voltage holds good and charges good. I also run my stereo sytem alot with the truck off, still seem to be fine.
Old 08-06-2008, 07:11 PM
D45
D45's Avatar
I just checked the date on mine and they are also the original factory batteries (2004).
The voltage is perfect and I do not have any starting issues.
I have heard of the stock set lasting 7-10 years.........
Old 08-06-2008, 08:29 PM
Patriot2500's Avatar
My batteries are also stock and the truck just turned 4 two months ago. They are holding up fine.
Old 08-06-2008, 08:36 PM
Como4076's Avatar
Talking
My buddy has a 2001 Club Cab and his batteries are the original ones pushing 7 years and they are strong no problems !!! " YET " But he is changing them out in the fall to get ready for plow season , he even said he has been pushing his luck with them !!!!!
Old 08-06-2008, 09:18 PM
03RAM2500's Avatar
MikeyB
Same here on my 03.
Old 08-06-2008, 10:10 PM
jballou's Avatar
At the first hint of failure they are gone. But not before then. Money could be spent elsewhere. I am resourcefull enough and knowledge able enought to know when. Stretching and gambling at the same time. A calculated risk.
Old 08-07-2008, 03:08 AM
Diesel Duke's Avatar
I have a 2003 Ram 3500 with original batteries. If your not having problems, save your money.
2003 Ram SLT QC.LB. 4x4, Patriot Blue,NV5600 Trans., 5.9 H.O.,305/65/17 Pro-Comp-Extreme AT's tires ,SS speed grille inserts, Bushwacker fender flares, ToughCountry rear bumer,Monroe Reflex shocks,Rhjno-Lining and mudflaps.
Old 08-07-2008, 04:28 AM
67HotRod's Avatar
I recently changed the ones out in my 01, only because I was getting nervous about their age.
Old 08-07-2008, 06:11 AM
Hounddog's Avatar
Orignals in my 03. My 1998 1500 went 7 years.
Old 08-07-2008, 06:14 AM
ColdCase's Avatar
When modern batteries get this old, they typically fail with a short in a cell or two. No warning, just suddenly no start. Will this take down both batteries, or does dodge isolate them? Will the truck start on one battery?
The original equipment batteries seem to last a long time, 6-7 years. Replacements less.
Old 08-07-2008, 07:51 AM
DiezelSmoke's Avatar
You can have the same problems with brand new batteries. Save your money until you start having problems.
Old 08-07-2008, 07:57 AM
06RAM2500's Avatar
Especially if your getting them on sale for $30. One went after a year and a half. So instead of monkeying around with a new factory, I went ahead and got two dry cells. They like the hot summers and cold winters much better!!
Quick Reply: How long do these batteries last?
