How to: Driver side door panel removal
Old 11-14-2014 | 09:57 PM
  #31
madhat's Avatar
Administrator/Jarhead
First I'd check the wires in the door jam. I haven't seen front door wires breaking, but it's possible. Pull the wire loom back and have a look.
After that, I'd pull the window switch out and check it with a meter, make sure it hasn't failed. You should (I think) be able to rob a switch from the back door that works and swap it to see if it works.
I'm assuming you've already played with the window lock button on the driver side?
Old 11-14-2014 | 10:58 PM
  #32
dezeldog's Avatar
Yup, roger on the "played with the window button". Thanx for info on swapping the switches.....I'll give that a try along with checking the wire loom coming through the door post.
Jim
ScreaminEagle
07-26-2011 05:47 PM
nomad65
08-20-2007 07:01 PM
LanceK
05-17-2007 02:54 PM
Rrloren
08-21-2006 09:49 AM
