How do I remove fin sensor in the evaporator
I have an '03 and the A/C has been freezing up and want to move the fin sensor in the evaporator. I cut a hole in the HVAC housing and can get my hand on the fin sensor but it won't just pull out. Is there a trick to it or do I have to get access the back of the evaporator? Also does anyone have the part number of the fin sensor.
Thank you in advance
Thomasg
Thomasg
I also have a 03, does the same thing. Ratlratl on here works @ a dodge dealership. He told me, just put it in the center of the evap, as it near one corner. Said no parts had to be purchased thou. Im dreading pulling apart the dash.
I had couple of people tell there is a tsb, but I can never find it. Looked thru all the tsb that geno's garage lists. Maybe somebody will put a link or something.
No tsb ...this is the star recomendation
Replace the evaporator temperature sensor with part number 5140727AA. Relocate the new sensor to the upper right hand corner of the evaporator. The distances are taken from the air exit side of the core, with the top denoted as positioned in vehicle. 5 5/8 inches (143mm) from the outside LEFT plate (this corresponds with the 12th fin column from the left) 2 inches (51mm) from the TOP of the plates (not the top of the tank).
rjweiss
06-01-2013 04:59 AM
annabelle
06-28-2010 08:42 AM
snakefarmer
08-13-2008 04:18 PM
