How do I Get Rid of Tire Hop
Dp you have the full leafs or the mini-packs?
They both help with wheelhop in loose conditions like snow and sand because they are a pregoressive spring setup to helps fight axle wrap. The stock spring in these trucks will twist pretty good until the bottom overload leaf hits the springs pack and then it abruptly stops an unloads the spring only to start the whole process over again. The progressive nature of a mini-pack or Carli full progressive leaf springs doesn't stop the twist but it limits the twist/stop/twist/stop process that happens with the stock leafs.
Your explanation makes sense, I was thinking more along the lines of the shock but the spring action that you describe seems more accurate.
Here's a discussion on ladder bars vs. traction bars.
https://www.dieseltruckresource.com/...s-t263740.html
I live up a long mountain road that I have to maintain. It is usually snowcovered this time of year. it seems that everytime my wheels start to slip (spin) I get severe tire hop. Not just once in a while either. Pretty much every single time. It feels like the driveshaft and tranny is gonna fly apart. It makes getting home in the snow pretty hard.
I know I need balljoints on the front. maybe (hopefully) this is the reason for the tire hop. I also just put new tires on it a few months ago and they are pretty aggressive treads which I bought for the purpose of making it home in the snow. They are the Hankook Dyna Pro MT's and they are one size larger than stock 285's.
Anyone have any ideas how to eliminate the tire hop?
s cesnick:
I had a similar problem with my 1996 Dodge CTD both on loose off-road surfaces and on the drag strip. I bought and installed a set of "Cal-Trac
Traction Bars from Calvert Racing and it COMPLETELY eliminated all of the tire/wheel hop. They were easy to install, they are adjustable (tighter or looser) and they are reasonably priced. They also have excellent customer service and they are well made.
Here is the website if you are interested:
www.calvertracing.com
John_P
s cesnick:
John_P
s cesnick:
John_P
they make a great traction bar! these will be the ones i get once i have the money.
Hoss
07-04-2003 12:31 AM
99 cummins
05-24-2003 12:27 PM
j
04-01-2003 10:08 PM
