HO 600 and overload springs??
I don't know for sure but you should be able to order the Ram 3500 overloads from your dealer's parts department. Make sure they order all of the related hardware including the stops that mount to the frame.
Can you do that, mount 3500 overloads on a 2500; I've been wanting to do something like this. The overload stops (I believe) are welded to the frame of the 3500's at the factory and I don't think you suposed to weld on the frame of the Ram HDs.
![Confused](https://www.dieseltruckresource.com/forums/images/smilies/confused.gif)
You can try timbrens. they easy to bolt on in place of the bumpstops. try Timbren.com I bought mine at Truckspring.com. get the 6000lbs set i have the 8600lbs they are to stiff i take them off when i dont need them. you might have to call them to do that.
gts95
08-05-2008 12:49 PM
