higher rpm on manual 07
I have noticed on my new truck the rpms are higher. Around 70 im running between 2200 and 2300 rpms. Did they change anything from the 06s? I mean this thing would probably redline at 100.
The 06s and 07s should be the same. I was pretty suprised the first time I got it on the freeway.. My 06 with the g56 ran about the same rpms as you mentioned until I got bigger tires. The 315/70/17 BFGs bring thr rpms down quite a bit.
From what I understand the Overdrive ratio was lowered (numerically) making the rpms the same as a 4:10 with 3:73's installed. Thats why you can't order a 4:10 with the G56. You can with the Auto, I understand.
Dave
Dave
I just traded in my 06 auto for an 06 Mega Cab 6-speed. And I noticed the same thing, 70 the rpm's are anywhere from 200-400 higher. I think that CoastalDav is correct in what he said.
I was told that the only thing that changed from 06 to 07 (besides the motor of course) was the tailights, badging and the front bumper a bit.
If you put 315 tires on your truck you would drop your ratio to 3.45. So with close to 30 points off the ratio I am sure you will see lower rpms. My truck drop 200 rpms at 70mph when I went up to 33's
D-roc
If I remember correctly, the rpms dropped by about 250 to 300 @70mph. It was hard to tell exactly how much at first because the speedo was off because of the new tires. (I didn't reprogram for larger tires until about three weeks after I got them.) I do a lot of freeway driving so the new taller tires actually helped mileage a little bit. The truck also takes off better from a stop because 2nd gear isn't as low anymore..
I need to GPS mine now that I have the 33" ProComps on! I wonder what speed I'm really running at 2200 RPM's that is showing 70 mph??????-----I put a stocker Michelin up beside the 33-12.5-17's that I bought and there was not that big a difference in the height???????
