Help me buy HIDs
Help me buy HIDs
Sorry for all the questions but I知 trying to get the whole scoop on what I need to buy hids in one post. My girlfriend wants to buy me HID Headlights and Fog lights for Christmas. I already know I want the BI-Xenon headlights and fogs in the 6k temp. I know I need to get the relay harness and while I知 at it I知 going to get the 6 ohm 50 watt resistor just in case I need them. How many resistors do I need to buy? Is it one resistor per headlight or two? How many will I need total?
As of now my truck did not come with fogs. I have those ugly black caps in there. I do have the wire that drops down by the driver side fog hole. My headlight switch does not pull out though if I tried to turn on the fogs. Do I have to buy the whole stock fog light assembly that comes with the wiring harness and dash switch?
What bulb does the fog痴 take on the 2005 Rams? Will I need to buy the relay harness and resistor(s) to make the fogs work just like the headlights. Sorry for all the questions. I just wanna make sure I get everything with one shipment that way when they come I can install them without waiting for more parts to come. Thanks!
I just installed HIDS in my 04 and i used a 8 ohm 20 watt resistor and didnt have any problems just use a t-tap and run a wire from the low beam wire to the ground.
Location: misplaced Idahoan stuck in Albuquerque, Roughneckin on RIG 270
DO NOT BUY FROM EFX (eurofx) customer service SUCKS, they don't and won't answer the phone or return emails! I finally had to go to another company to get the harnesses I needed to trick the "lamp out light" and keep them from flickering. www.hidspeed.com KILLER customer service, hand made the harnesses I needed and had them to me in 3 days. AND they answer the phone, return emails and help troubleshoot any problems. Don't go with cheap kits.
I went to xenongate.com and they have two kits.
1) 9007 Bi-Xenon HID kit
2) 9007 Hi/Low HID kit
I thought bi-xenon meant that it was a high/low beam kit. So now I'm curious what the difference is between the bi-xenon and high/low kits?
The Bi-xenon is the better kit because the high and lows are HIDS, and the hi/low kit has hid lows and halgoen highs, i have the hi/low but the highs suck, but the hids are so bright you dont really need a high.
General Design Lighting has a BI-XENON HID kit that comes with two balllast,2 bulbs,and all wiring said to be plug&play no cutting or splicing takes approx 20 minutes to install comes with 6k bulbs,but you can get 8k or 10k,but the guy I talked with said depending on where you live you might have some legal issues with the 8 or 10k. kit complete 244.95 he said he also had hid kit for fog lights that if you boght both you could get for 400.00. has anybody seen these. I am especially interested in the plug&play part.
I have bixenon for headlights and the fogs are done as well. 8000k for all of them. I can drive around on my fogs alone now! LOL
plug and place is cool but i would be worried about burning up the factory harness. I would get the relay kit which provides direct power from the battery and the factory harness triggers the relay. then you have no worries about doing damage to the factory harness. I did that on both headlights and fogs to prevent damage.
I paid $67 a set and they came with everything needed. No resistors at all and no "Lamp Out" indicator either. They supplied the capacitors needed so that the lights didn't flicker at all.
For $65.00 you couldn't go wrong. These lights have been very reliable. I thought that $65 bucks I would give it a shot and I am glad that I did. I only did the Hi/Lows, but that is because I clicked on the wrong link. Still, all the same price, hi/low or bi-xenon.
If you are interested I have the email from them stating the prices they quoted. PM me your email and I will give you their information.
im looking at this mod as well any chance your could post a pic to see how blue the 8000k's are ive already had the 6000 and was happy with them in my 02 tj but i really would like these to stand out and we get lot's of fog here and the blue is supposed to cut the fog better ?
cheers if you can i know night pic's can be hard to get the real feel
thanks in advance
thanks in advance
thanks in advance
