Heat only working part time
Same problem with my truck. Open glovebox. Look for a metal rod that is connected to the upper blend door.
Either upper or lower blend door is broke.
Google heater treater.com for a fix without tearing the dash out.
I just replaced all my doors with metal. Heat runs me out of the truck now.
You have 1 or 2 broken blend doors causing your trouble.
Common thing to happen with our garbage hvac systems.
Carey
Carey
[QUOTE=madhat;2715726]When you say 'kick it,' you mean... (not trying to be a smart butt...).
QUOTE]
opps suppose to be Kick IN LOL it was past my bed time ...
QUOTE]
Carey
Carey
BTW I am so addicted to here and the other forum like this LMAO I use to sit on my horse forums now I am sitting on here
If you're going to do them all with the Heater Treater doors, do it right and drain the coolant and discharge/disconnect the A/C lines, remove the dash and HVAC unit, then replace all of the doors. I am not a fan of cutting into the HVAC box to avoid an extra 30 minutes (if that) of work. My write-up I mentioned earlier covers this exact procedure. Remember also, that if you don't have good heat now, you won't have cool A/C when the weather warms up either.
Learn here: http://www.heatertreater.net/Ram%2002-08%20Listing.html
Buy here: http://cgi.ebay.com/ebaymotors/combo...Q5fAccessories
Hope this helps.
Hope this helps.
In my experience, your doors are broken or stripped where the coupler engages the axle of the door. The actuator has to turn a greater amount before the coupler/door junction can engage each other enough to move the door into position. This is common and you should fix it. It could become a safety issue when you need to defrost the windshield but cannot.
tswcoaltrain
11-12-2019 09:11 PM
Diesel4blood
04-11-2011 12:29 PM
crash4wd
10-17-2009 03:06 AM
