Heat only working part time
Old 03-02-2010, 11:40 AM
Peggy Sue's Avatar
I just got a 2003 Dodge 3500 4X4 with the Cummins and my heater only works part time. Blowers work fine but only blow cool air HELP??
Old 03-02-2010, 01:59 PM
HOBrian's Avatar
Sounds like one or more of your HVAC doors are broken. Many many many many problems with those stupid doors!! Do a search when you have hundreds of hours of time to kill!
Old 03-02-2010, 03:33 PM
Peggy Sue's Avatar
so I should search for HVAC doors not heat?? I tried searching heater and heat knew I was doing something wrong
Old 03-02-2010, 06:39 PM
1985cucv's Avatar
turn the heat dial with the fan on low and go from there see if that works!
Old 03-02-2010, 08:11 PM
Peggy Sue's Avatar
will do this tomorrow and get back with you :0
Old 03-02-2010, 08:19 PM
kry226's Avatar
Also, remember that it takes a long time to warm up all of that oil and coolant. You won't have heat immediately on a cold morning.
Old 03-02-2010, 08:21 PM
Peggy Sue's Avatar
Got her Sat drove her two hours home in 30* temps with NO HEAT LMAO .. I really wanted this truck and I tend to be blonde at times
Old 03-02-2010, 08:27 PM
Peggy Sue's Avatar
on "average" (I know each is different) how long should it take for the heat to kick in??
Old 03-02-2010, 08:38 PM
kry226's Avatar
You should have good heat in 10-20 miles, depending on how hard the engine is worked, obviously. Definitely should have been warm with a two hour drive.
Sounds like you might have a broken blend door. The blend door manages the temperature of the HVAC system. I just did a write-up about replacing broken doors last week. It shouldn't be too many pages back.
Now, there were some guys who were installing heater core by-pass valves in the heater lines to make the A/C more efficient. Might want to check under the hood, on the passenger side of the engine. There is a rubber hose coming up out of the engine block that turns rearward and enters the firewall. If so, the valve would be located in this area. Just need to open it to let warm coolant flow through the heater core.
Old 03-02-2010, 09:01 PM
Administrator/Jarhead
madhat's Avatar
Or, not to be the bearer of bad news, that is also a sign of the water pump failing.
Check your coolant level also.
Are you feeling no heat at all, like, the cab is still frigid, or are you just not feeling any air moving?
Old 03-02-2010, 10:08 PM
Peggy Sue's Avatar
There is air it is just not warm.. and it does kick it every now and then
Old 03-02-2010, 10:09 PM
Peggy Sue's Avatar
kry I found several on changing the doors out and have them all marked
Old 03-02-2010, 10:11 PM
Peggy Sue's Avatar
The flow is strongest out of the window vents(defrost) when we move the switch there is light air but not much on other settings??
Old 03-02-2010, 10:12 PM
Peggy Sue's Avatar
should I video me trying to change it all out? not a pretty site I will assure you LOL
Old 03-02-2010, 11:27 PM
madhat's Avatar
When you say 'kick it,' you mean... (not trying to be a smart butt...)
This sounds like a blend door. There is a way to just take it out without having to remove the whole unit.
If you are getting no heat at all, check the heater core lines, as was stated above, and check your coolant level.
Quick Reply: Heat only working part time
