Gravity feed aux fuel tank question.
Old 09-05-2008, 11:46 PM
  #31
Diesel Doc's Avatar
If you must do gravity feed at least put a valve at the bottom of the aux tank just in case for some reason your main system pops a leak of some sort or you are involved in an accident you don't end up dumping 100 gallons of diesel into the street.
Old 09-06-2008, 04:41 AM
  #32
2500's Avatar
planning on carrying WMO... so prefer manually pumping oil into tank.
Old 09-06-2008, 05:48 AM
  #33
Flopster843's Avatar
Originally Posted by Ramyes
Here is a link to the T that fits into the filler neck and has a ball float that shuts off when the main tank is full. I have had one of these on my truck for about a year, just fill both tanks and let it gravity feed. never a leak.
http://www.northerntool.com/webapp/w...5501_200315501
I have this same setup on my broken turd of a truck and have had it there for several years. It's about the only thing that hasn't broken. It has a ball valve in the bottom of a 93 gallon tank in the bed, goes in to a filter/water sep, then in to the float valve in the filler neck. I just open the valve before I make a trip and let it gravity feed the entire way, then close it when I'm where ever I want to be. It has never leaked and never over flowed. I'm going to transfer it over to whatever truck I buy when I get back. And in case you're wondering what will replace it, I am on DTR...
Old 09-06-2008, 07:44 AM
  #34
FiverBob's Avatar
Here is a link with pictures on my installation. Since I wrote that, Northern Tools now has an installation kit from RDS that makes installation a piece of cake. They also carry the RDS tank which is a very good quality tank. I highly recommend Lightman's addition of the ball valve. I did not use the main tank vent line for feeding which technically changes the dynamics of the factory installation which I hear is a no no in some states. The insertion of fuel in the filler pipe pretty well follows the intent of that part. I did not add the filter since I am going into the main tank anyway which is filtered, but that is probably a good idea. Be sure you put a locking cap on that aux tank - - makes it too easy for someone to grab a bunch of your money real quick. I did rinse the tank out with some diesel before installing "just in case". (it was clean!!) The RDS tank does have a gauge inside the tank, but I also just watch the dash gauge - - when it starts to move I know the aux tank is empty.
I have had my tank in now for 5 years - - I love it. I turn it on while on the road and run on it. I turn it off otherwise. It does not matter if it is a bit slow - - I certainly don't sit there and watch it. Sometimes I will let the main run down to about 1/4, then turn it on. Now wires, no pumps, no valves. I have had pumps and valves fail me and ended up stranded in the desert in my motorhome - - no thanks. I am not so lazy I cannot reach over the bed and turn a valve - - called the KISS principle.
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Bob
Old 09-06-2008, 09:46 AM
  #35
roughstock's Avatar
I run a gravity feed aux tank on my truck. I went to Napa and got a fuel valve, like the one that you see on dual tank chevys. There is a one wire hook up. I toggled it in the cab. one side is plugged and when i flip the switch, it opens the valve to the aux tank to dump in to the main tank.
Old 09-06-2008, 09:57 AM
  #36
CrazyFloyd's Avatar
I put one of those valves that are meant for your oil pan on the bottom of my aux tank. Still fighting the overflow problem.
Old 09-06-2008, 08:44 PM
  #37
FiverBob's Avatar
Have you changed your gas cap to a locking cap? Could that cap be leaking? It is my understanding they are supposed to breathe in only and not allow fluid to come out. Mine never overflows and I have an 03 but with locking cap. It did not overflow with the stock cap either.
Old 09-07-2008, 08:53 AM
  #38
CrazyFloyd's Avatar
It does not leak from the cap; it leaks from the stock tank itself (I think from the big plastic ring on top of the tank).
Old 09-07-2008, 11:11 AM
  #39
dezeldog's Avatar
I read somewhere that there's another vent tube or something of that sort on top of the tank, within the plastic ring that has a cap on it. They say that possibly that cap is not diesel rated and has rotted out. Since I have the vent mod I used the old vent for the feed from the aux tank. I have had a grav. fed aux tank for about 2.5 yrs with no issues at all. Hope this helps.
Jim
Old 09-07-2008, 04:50 PM
  #40
haulin-rv's Avatar
I have gravity fed on my last 5 trucks for a total of over 1,000,000 miles (no typo). Its 100% legal to gravity feed into the trucks tank. It will not overflow, as long as you do not tank the fuel cap off on the truck. I run a ball valve on my tank to turn off the flow if I want.
Old 09-24-2008, 02:27 PM
  #41
macattack_ga's Avatar
Originally Posted by TJAR66
Isn't gravity feed illegal. I don't know I thought I heard it somewhere when I wanted to do the same thing
law specifically says you can't gravity feed to carb (or injectors I think).
tank to tank or tank to lift pump is not mentioned in the law.
welndmn
16
03-31-2020 10:16 AM
beardedone
09-09-2008 01:58 PM
CrazyFloyd
08-13-2007 02:41 PM
svanni
13
09-06-2006 07:37 PM
deviousracing
05-19-2005 03:35 PM
Quick Reply: Gravity feed aux fuel tank question.
