fuse box
Old 03-17-2007, 08:53 PM
53 willys's Avatar
Originally Posted by wreedz71
is there a relay somewhere for the wipers?
here......first one on the far right (looking top to bottom)
*EDIT* never mind wrong year I guess
Old 03-17-2007, 08:54 PM
wreedCTD's Avatar
****** the 06s no longer have that fuse box. mine already has fuses for "AISIN CONTROL MODULE" i have found the fuses but there are no relays.
Old 03-17-2007, 08:55 PM
wreedCTD's Avatar
see pic, this is my fuse box right next to the drivers side battery.
Old 03-17-2007, 09:02 PM
53 willys's Avatar
I'm confused I looked that up under your truck's year but I know my 06 does not have relays in the fuse box ether....
when I looked it up it said it was in the relay box but then when I went back and checked it said the relay box was the fuse box
its making me feel dumb
wreedCTD's Avatar
tell me about it, ive been trying to figure it out since 7am this morning
Old 03-17-2007, 09:04 PM
butchb's Avatar
Yea mine too. And there ain't many fuses!!
Old 03-17-2007, 09:05 PM
wreedCTD's Avatar
did they get rid of the relays? maybe its all controlled by the computer, becuase the SM did tell me they did a flash for a wiper problem.
Old 03-17-2007, 09:53 PM
53 willys's Avatar
try disconnecting the batteries for a while see if it changes anything????
just to make sure the power is drained turn the key to the start position before you hook the batteries back up..
let us know what you find.
Old 03-17-2007, 11:35 PM
DTR's 'Go to Guy'
vzdude's Avatar
What exactly do you want to know? Which fuse of for wipers?
FUSES (TIPM) - 42 WAY FUSE NO. AMPS FUSED CIRCUIT FUNCTION
1 20A A405 18RD/DB FUSED B(+)
2 20A A941 18RD FUSED B(+)
3 - - -
4 - - -
5 20A A310 16RD/LB (EXCEPT BASE) FUSED B(+)
6 40A A212 20RD/OR (DIESEL) FUSED B(+)
6 10A A956 20RD (GAS) FUSED B(+)
7 15A A917 18RD (SRT) FUSED B(+)
8 10A C16 18DB/GY (EXCEPT BASE) HEATED MIRROR CONTROL OUTPUT
9 30A A121 14RD/YL (POWER WAGON) FUSED B(+)
10 5A T41 20YL/DB (EXCEPT SRT) PARK/NEUTRAL POSITION SWITCH SENSE (T41)
11 20A A114 18GY/RD FUSED B(+)
12 30A A400 14TN/RD (TRAILER TOW) FUSED B(+)
13 25A A111 14DG/RD (AWAL) FUSED B(+)
14 15A L7 20WT/YL FUSED PARK LAMP FEED
15 20A L678 18BR FUSED PARK LAMP FEED
16 15A L70 20WT/GY FUSED PARK LAMP FEED
17 - - -
18 40A A107 12TN/RD (AWAL) FUSED B(+)
19 30A A100 14RD/VT (TRAILER TOW) BACKUP LAMP FEED
20 10A F100 20PK/VT FUSED IGNITION SWITCH OUTPUT (RUN)
21 10A F201 20PK/OR FUSED IGNITION SWITCH OUTPUT (RUN-START)
22 2A A106 20LB/RD FUSED B(+)
23 10A A919 20RD FUSED B(+)
24 20A A916 16RD FUSED B(+)
25 10A A940 18RD FUSED B(+)
26 15A A103 18GY/RD FUSED B(+)
27 40A A210 12OR/RD FUSED B(+)
28 10A F202 20PK/GY FUSED IGNITION SWITCH OUTPUT (RUN-START)
29 10A F21 20PK/DG FUSED IGNITION SWITCH OUTPUT (RUN-START)
30 - - -
31 15A A918 20RD (EXCEPT DIESEL MTC) FUSED B(+)
32 10A F504 20GY/PK FUSED IGNITION SWITCH OUTPUT (RUN)
33 - - -
34 - - -
35 15A A944 20RD FUSED B(+)
36 25A A116 16YL/RD FUSED B(+)
37 - - -
38 20A A205 18RD/OR FUSED B(+)
39 10A F983 20PK/YL FUSED IGNITION SWITCH OUTPUT (RUN-ACC)
40 20A F984 18PK/YL FUSED IGNITION SWITCH OUTPUT (RUN-ACC)
41 - - -
42 30A A209 10RD (DIESEL) FUSED B(+)
Old 03-17-2007, 11:38 PM
DTR's 'Go to Guy'
vzdude's Avatar
Not as specific as I though originally. but fuse 2 deeds the cluster that feeds the intermittent wipers.
Old 03-18-2007, 12:10 AM
53 willys's Avatar
3 - - -
4 - - -
17 - - -
30 - - -
33 - - -
34 - - -
37 - - -
41 - - -
oh, now I get it
Old 03-18-2007, 07:44 AM
79warlock's Avatar
TIPM fuse 2 is a main B+ feed to the cluster, you will loose a lot with that fuse removed. The wipers are powered by driver's in the TIPM which is why there is no fuse or relay.
Why are you asking these questions anyway, are you trying to diagnose something?
Old 03-18-2007, 10:49 AM
DTR's 'Go to Guy'
vzdude's Avatar
Hope these wiring diagrams help. Just shows fuse, and TIPM . Not much else to tell you unless you have a scan tool to read BCM inputs and TIPM inputs.
Old 03-18-2007, 01:46 PM
wreedCTD's Avatar
Yes, my windsheild wipers quit working yesterday morning. everything else on the truck is working OK. i check fuse 2 also and it is fine.
Old 03-18-2007, 02:10 PM
wreedCTD's Avatar
anyone had this problem with a newer truck that has the TIPM?
Quick Reply: fuse box
