Front tires cupping
Front tires cupping
My front tires are cupping at 34500mi,there is no vib or steering pull just the howel,any ideas other than replacing them?Any one else have this problem?The inside tread on both front tires are cupped.
What air pressure have you been running in them
How oftem have you been getting them balanced and rotated
Have you ever had an alignment done
Answer these questions and you may infact hav ethe answer to your own question
When running empty you should have running about 50psi in the front and 40 in the rear, asuming this is an 2500 or 3500 SRW per the tire info book that's in the glove compartment
Loaded you should be running around 60 psi front and 75 rear. This info is for the 03, SRW 3500 so most are about the same.
I currently have 48k on mine (BFG's) and still have about 8mm left, roughly 1/2 the tread.
Fill out more info on your truck so we can help you better also.
Again, ck your upper ball joints. If they are loose, it wil cause the insides of the tires to wear first and can cause the cupping you are talking about. That is my suggestion.
EB
EB
Originally posted by Hounddog
How many miles between rotations? How often is trailer pulled? The trailer affects alignment.Weighted bed nose of truck comes up etc.
Well I finally got the truck into the shop to sort out the cupping front tire problem and after a complete front end check the caster,camber and toe where well inside OEM specs,the ball joins were good,tire pressures were spot on,that left tire rotation as the cuperate,10,000 mi's is too long before rotation.We took the cupped fronts and put them on the inside rear and put the outside rears to the front, the next rotation at 7000mi will have the now outside rears crossing over to the fronts and the fronts going to the rears.The truck now drives with out any howel.The lesson here learnt is to rotate every 6-7000 mi not 10-12mi.
sakisaki400
23
12-31-2006 10:17 PM
belfert
18
07-27-2004 05:25 AM
gdh11
04-07-2004 01:18 PM
