Factory Sirius Satellite Question!! Help Plz
Well hello everyone i have a few questions for you sirius guru's !!
I bought my 06 Mega Used and am not sure if it has Sirius...
The build sheet that the dealer provided me with says it does however i am questioning that....
Its a 6 disc infinity (RBQ i believe), but there is NO roof mounted antenna, and it does not say "sirius" on the receiver anywhere (or even go into "sirius" if i click the mode button).. I would really like to add sirius to the factory stereo, and not go with an aftermarket deck... If it is possible to add sirius does anyone have a source where i may be able to see the prices on adding it on.
Thanks
ADam
Thanks
ADam
Most likely the unit is not installed in your truck. The stock Sirius tuner should be located above the glove box. If you remove the glovebox and look up it should be right there. If not, you do not have it. PM SENT!
Mine is located on the roof near the back of the cab...
Does your guy's screen look like this...?
When I took this picture, I was shooting the exhaust brake, but you can see the screen...
I gonna say no antenea no Sirius. But you most likly can install it on your factory radio.It all just plugs into the back,than have it activated. I got all my stuff of ebay for around $120. Install kit and receiver all was brand new. I love it! Good luck.
If you have an antenna it should be at the back of the cab like megacabdad said. It will be a fairly flat black plastic piece. If there is nothing on the top of the cab then you are right about no antenna.
If you need to add it, the head unit should be ready to just plug and play. No need for that extra piece to mount. Not sure about the antenna though.
Thanks
ADam
Thanks
ADam
After you install it the mode button will scroll from satty radio to CD to FM to AM and so on. With the XM direct adapter I can program up to ten satty radio channels on my presets. I don't know why I can't get all twelve but rarely switch between more than five channels on there anyways. You still have all the FM and AM presets available when you switch modes.
I have sirius in my truck, but let it lapse and went with a portable unit. I can connect to the factory radio using the AUX port or I can take it with me anywhere. Same goes with things like NAVI, a factory unit would be nice but for half the price I got a Garmin that can update itself plus I can take is car to car. Portability rocks!
yellowhemi
05-14-2009 12:16 PM
Steven K
14
04-26-2007 02:25 PM
RedRacer44
52
04-09-2007 03:24 AM
Dieseljunkie
12-16-2004 07:46 PM
