Factory Manual Incorrect???
Old 11-02-2006 | 03:35 PM
pet05's Avatar
I read that my 2006 3/4 ton has only ONE spot that need to be lubed & that is the the infamous shaft location. I lubed that spot. PITA
But, while looking underneath I found one grease zerk fitting on each end of the sway bar. So 2 more greasable spots?
Why wouldn't DCs manual state that??
Old 11-02-2006 | 03:51 PM
Peterbilt's Avatar
That's interesting. Usually, there is a zerk at each tie rod end and the front drive shaft on 05/06s.
Pete
Old 11-02-2006 | 05:42 PM
pet05's Avatar
I'm sorry, you are correct. The zerk is at the end of each tie rod.
Why does the factory manual leave this out???
Old 11-02-2006 | 06:03 PM
Jeff in TD's Avatar
That's strange. My 03 manual says to lube the tie rod ends that are only on 4x4's, but doesn't say anything about the front drive shaft...
Old 11-02-2006 | 08:14 PM
cdru's Avatar
My manual points out both tie rod ends and the front driveshaft grease points. It may be listed in the maintanance booklet that comes in the manual folder. cdru
Old 11-02-2006 | 08:58 PM
pet05's Avatar
So on a 2006 4x4 there are THREE spots to grease -
Driveshaft
2 Tie Rod Ends
Nothing else, correct??
Old 11-02-2006 | 11:10 PM
cdru's Avatar
That is correct. Only three grease fittings. cdru
iker42
24
11-25-2006 08:13 AM
walexa
02-22-2006 07:26 AM
GarettD
09-17-2004 11:57 AM
Lary Ellis (Top)
11-28-2002 07:27 PM
Quick Reply: Factory Manual Incorrect???
