Factory hitch wiring 7-pin
Does anyone know if the center connector on the 7-pin connector is wired to the back-up lights? I want to add some Serious back up lights to my trailer and was going to use the connector pin to activate the relay. Also I have a friend that says his one of his connector pins charges his trailer battery and it's not the hot pin. I can't find anything to back this up mine says the #4 pin is hot but that's all I can find. Thanks in advance for any advice
http://www.marksrv.com/wiring.htm
Try this link out. If you have a meter you should be albe to read 12 volts between pin 1, the ground, and pin 7, the back up pin.
Jon
Cowboy_Customs
10-18-2011 01:46 AM
