EGT guage and dimmer switch
On my 2004 I'm pretty sure I used the orange with brown stripe. Your wire colors might be different. If you have a test light probe until you find it. My manual says there are 2 OR/BR wires so if you find two wires coming out of the back of the headlight switch that are the same color then those are probably them. Use a test light or voltmeter to verify.
If you pull the panel that the headlight control is in you will find a modular plug with six wires on the back side. You want to t-tap into the orange wire with the brown stripe. It is pin number 2. If you pull the plug out of the socket the pins are number inside the socket.
jesse123
07-08-2012 09:04 PM
Charlie8301
18
07-29-2006 02:30 PM
ckennedy
11-15-2004 06:54 PM
