dually tire question again
All right I know this has been posted on here before but I want y'all to break it down for me. I'm wanting to run 285's on my truck. I realize that I am going to need new spacers for the duals. Where do I get them and how big do I need? I've talked to several local tire stores around here and none of them have ever put bigger tires on a dually. So break what I need to do down for me please. Thanks
Ross
Ross
I just went through the same process, and after about 3 days of research have decided to go with some Toyo 285/75-17s, which I just put on order with one of the only dealerships that carries them around here. They are an E-rated 34x11.5" tire, and I was looking at 35" tires, but they were all D rated, which on our skinny rims would create too much sidewall flex under load. The spacers I got I ordered off of ebay, and I got the 2" ones, which will give me plenty of room between tires, but I also won't have to trim the original lugs to make them fit.
What BgBlkTrk said,
I've been running the Toyo 285/75/17 with Rockstar wheels for a couple of months and love'em. 2" spacers give me a little over an inch between tires. The Rockstars have a little less spacing than the stock steels so you should have a little more clearance. They fill the wheel wells so much better than the stockers and they look and ride great.
What BgBlkTrk said,
Thanks.
Yup-it is 8x6.5, and if you can believe it, I called 2 local dealerships to verify this, and neither of them knew what I was talking about! I finally had to go out and measure it myself. Thanks again CJHauler-you led me in the right direction!
Its all going to be dependant on what space you are comfortable with between your tires and what you use them for-I have read about people that have larger tires that rub under load slightly and they are fine with that, and others that have a tall skinny tire and small space between them: https://www.dieseltruckresource.com/...d.php?t=170380
You would just have to watch your tire pressure and sidewalls under load. Hope this helps!
Steven K
06-04-2009 10:32 AM
epenn03
01-05-2006 03:39 PM
j28s
10-14-2002 09:48 AM
