Dually tire pressures?
A friend had new tires put on his 95 dually Ram and they had<br>his rear tires aired to 60 lb's. He said he was going to Nebraska<br>the next day( from Az ). I told him he should let his back tires<br>down to about 45 lbs and front about 55lbs. I said his back <br>tires running empty with 60lbs the truck would ride real harsh,<br>and ride better at 45lbs.He then went and asked the dealer<br>and the dealer said absalutely not-only run it at 60lbs or the <br>tires would come apart.I say the dealer only wants the tires to<br>ware out sooner etc. What do you guys think?
Re:Dually tire pressures?
I called 2 other tire dealers-1 said 45 lbs was the safer <br>pessure and 1 said 60 lbs was about rite. I think on wet<br>roads the lower pessure gives more traction so it would<br>be what I would use. What do you 2nd gen trck owners<br>use?
Mine's an oldie, but the manual says if you're unloaded - 45 psi all around. I've heard you shouldn't go below that on an LT tire because it causes excessive sidewall flex. My truck feels real "nervous" with 60 psi empty, 45 is much more stable.
"I think" that as long as you don't reduce pressures to the point where the tire bulges rub against each other, you'll be fine. 'Least thats how I thought when I had my old CC ford big dooley. I think I used to run around 45-50 in them back aft. Then again, at 6-8 mpg I didn't drive it much either......
The door sticker on my 01 3500 says 50 rear and 55 front. I have ran both at 60 psi since day one. Tires now have over 66000 miles. Should I remove some air to make them last longer :
I pull heavy loads almost every mile. And I have the tires on my 03 3500DRW set at 70 psi rear, and 60 psi front. It rides good that way. But that is with the 235/80/17's..
You must haul alot with 70# in the rear. That would not be very comfortable when running unloaded. I am running 60# front and 50# rear.
Thanks for all the different opinions. Here where I live we<br>have some steep dirt roads that arent kept up,and I found it<br>hard to climb some of them with 60lbs air in back. So when I ran them at 45lbs its been no praublem.And I have to drive in<br>snow sometimes and I figured the extra traction there and on<br>wet roads was wirth leaving them at 45 in back for safety <br>reasons. I was still able to get 48000 miles on my first set of<br>tires. Thanks
I have expiremented with every range from 45 up to 80. I got 75000 miles out of the first set of tires running 65 in the rear and 70 in the front and rotating every 9000 miles. Even at 75000 miles, the tread was flat across on all six and they would have gone farther had I wanted to push them. I pull up to 26000 pounds on ocassion also.
Racfan9
12-08-2009 03:06 PM
O.T
09-18-2007 12:50 PM
toupee
06-27-2007 04:19 PM
