Dually rear tire psi. What is correct?
Old 05-20-2007 | 10:02 AM
AgentOrange's Avatar
I am getting uneven tire wear on my rear duall's. The outer tire seems to be wearing more quickly than the inner even though they are the same PSI. I tow a 5th wheel often so I usually just leave the rears at 65psi. Should I be running less air when not towing and should the inner/outer psi be staggered at all?
Thanks for any input
Old 05-20-2007 | 02:20 PM
GMScott's Avatar
I believe 65lbs. psi is the max. as indicated on the door sticker. Inner tire wear is normal. Meticulous rotation is the solution that I have found.
Old 05-20-2007 | 02:38 PM
Totallyrad's Avatar
I run 30 in my rears to get them to wear evenly. The outer tire will wear out faster than the inner unless you rotate them.
Old 05-20-2007 | 10:27 PM
92'1stGen's Avatar
the sticker on the door says 45 for light load and 65 for max load
Old 05-21-2007 | 06:28 PM
ASHNBAK's Avatar
Tire guys say 25-30 psi when empty if you don't want to wear the centers. I'm about 29 or so.
38 Cigarette
16
08-29-2015 12:27 AM
danalex
10-04-2008 12:23 PM
REDNECK-WELDING
05-29-2007 12:29 PM
dodgestang
20
08-06-2006 01:41 PM
ckennedy
09-29-2004 06:06 PM
