DTR Megacab Club
Old 02-13-2007 | 08:48 PM
  #181
D.Wiggs's Avatar
Originally Posted by txfiremedic
Very Nice!!! You're living right brother!!
I do the best that I can!
Old 02-13-2007 | 09:08 PM
  #182
txfiremedic's Avatar
UPDATED MEMBER LIST
Member # Name
1 txfiremedic
2 D. Wiggs
3 rockcrawler304
4 jonesm8
5 53willys
6 luvnacumns
7 06megacabman
8 fireflyr
9 tool
10 Strea
11 Mule Man
12 HayHauler1
13 Megaboom
14 mkivbren
15 Rockram
16 UT Fan
17 Longhorn06
18 Heston_ram3500
19 Tee
20 robertc82
21 Cmullen
22 FirstDodge
23 polishammer
24 04ctd
25 JOECUMNS
26 gRahAM Diesel
27 Unit44
28
29
30 Lost Texan
31
32
33 Festus
44 darrenb
45
46 hardtarget870
54 Hotazdiesel
64 Toynrnd
69 drakeslayer
99 Geico266
  #183
Luvnacumns's Avatar
Originally Posted by JD Dearden
Just looks like a list of biggest dorks ever if you ask me. Especially wiggs (owner of satin's limo) , luvenacumns he is from Idaho so that exsplains alot, ***** from lehi will just call him Kevin Bacon from now on, hay haulin guy, the hawaiin, and the guy who thinks he is a pilot.
http://forum.abestweb.com/images/smilies/ecomcity.gif
OOOH you only wish you were in Idaho!!! Besides I remember a time when your location was crying about no being here!! It's not our fault you can't be in the big boyz club !
Maybe you should start a 7" bullhauler club!!
Later JD
SHane
Old 02-13-2007 | 09:11 PM
  #184
bigredBCS's Avatar
jd is a proud member of the non-mega cab club! how many of you mega cab club guys have been in dieselpower magazine? huh? huh?
Old 02-13-2007 | 09:16 PM
  #185
Luvnacumns's Avatar
OOOH that's a low blow since he's wishing he hadn't done it now!!!!
Shane
Old 02-13-2007 | 09:17 PM
  #186
bigredBCS's Avatar
whys that?
Old 02-13-2007 | 09:55 PM
  #187
w.tx iceman's Avatar
hey some of us can drive st quad cabs and still feel like a man
Old 02-13-2007 | 10:05 PM
  #188
mkivbren's Avatar
Is VES available for the quad cabs? I have an 06 ctd quad cab work provided truck that I might buy out of the lease.
Old 02-13-2007 | 10:12 PM
  #189
53 willys's Avatar
yeah Kevin Bacon
Old 02-13-2007 | 10:27 PM
  #190
rockcrawler304's Avatar
As for stuff behind the back seats.... I have spare fuel filters, tools, first-aid kit (a very large one), small box with rags in it. Not too long ago I had all this AND a 42" flat panel television STILL IN THE BOX and was still able to keep the seat backs in thier full up position!!!
Old 02-13-2007 | 11:36 PM
  #191
Mule Man's Avatar
Originally Posted by D.Wiggs
It can be done, but it won't look right. When ever you photochop something black, you can never make it as black as you want because otherwise it will eliminate all luminosity and it will look like a black hole. I could do just about ANY other color other than black.
It is easy. Just set your color to black. select the paintbrush tool, and then set the blend mode to color or soft light , or multiply ( try each for preference)and paint over the bblack areas of the truck. adjust curves to get the right density. If you paint in those blend modes you maintain the transparency. Paint with 100% opacity. If you go outside the body of the truck and remove the color there, just paint it back with the history brush.I teach photoshop at the college. Edit: found your pic. Did not know it was white. I had to use hard light at 30% and a couple of swipes then curves. It is a real small file and there is a few jaggies. 4 minutes in PS
Old 02-13-2007 | 11:51 PM
  #192
D.Wiggs's Avatar
WOW! That is REALLY cool!!! I only know enough P-shop to be dangerous to myself!
I wish I knew all of that stuff. I am going to try it now!
Old 02-13-2007 | 11:54 PM
  #193
D.Wiggs's Avatar
Answered my own question!
Old 02-13-2007 | 11:57 PM
  #194
D.Wiggs's Avatar
It does not work at all for me!
Old 02-13-2007 | 11:59 PM
  #195
06megacabman's Avatar
OK, how about a Mega Cab club how to post with pics. (although it applies to other models too I'm sure) . Did a search on this in DTR and found the answer but thought I would post actual Mega Cab pics.
Just got my front 2" leveling kit installed and need to adjust the headlights down. From what I have read in the thread search here are the up/down torx adjuster screws location.
Drivers side looking down between radiator and lamp assembly
Adjuster bar that extends out to the torx head
Driver side headlight assembly holding left edge trim back
Now from what I have read it seems that turning the torx screw counterclockwise causes the beam to lower.
Quick Reply: DTR Megacab Club
