driving/fog lights for 2003
My 2003 has the holes in the bumper for the lights put it came with plastic louvers.Has anybody mounted lights in these holes? What size and or type did you use?
Re:driving/fog lights for 2003
I put factory fog lamps on mine. Mopar makes a kit that comes with everything you need to put the lamps in. Go to your parts department and give them this code: 82208102<br>The kit includes the lamps, wiring, relay, and switch needed to add the lamps. The kit is about $170.00 and is breeze to install. Its a bit pricy but it looks stock.
I'm pretty sure they are 75 watts, I will double check. The only problem with using aftermarket is designing a bracket to hold the lamps behind the louvers. Trust me I looked at it and there is not a whole lot options unless your good at "Jerry Rigging". I wonder if you can buy the brackets seperate then use like a wal-mart brand of fog lamp??
[quote author=TON4FUN link=board=17;threadid=8462;start=0#82230 date=1040283936]<br>I'm pretty sure they are 75 watts, I will double check. The only problem with using aftermarket is designing a bracket to hold the lamps behind the louvers. Trust me I looked at it and there is not a whole lot options unless your good at "Jerry Rigging". I wonder if you can buy the brackets seperate then use like a wal-mart brand of fog lamp??<br>[/quote]<br><br>You are suppose to take the louvers out when you have the driving lights......
Yeah I know I was just saying. I saw a few guys running around with 1500's that did not cut them out. They moved the lights back a bit so it would not melt the plastic. Like I said jerry rig it or do it the right way and get the mopar kit. FYI mine are 51 Watters.
fjbiker86
37
12-09-2007 07:29 AM
msatow
09-27-2006 07:32 PM
