Drivers door panel
Administrator/Jarhead
There are a few screws. They are in the cubby's, and on the top part closest to the dash. You have to take the opening lever off also, I believe it is either a hex or a torx.
Once you get the door panel loose, lift it straight up. It will pull away slightly from the door itself. You need to reach in and unhook the wiring harnesses from the switches, I believe they pull straight down.
When the clips are broken off that assy, I believe it pulls straight up. Take a little glue and reattach, then reverse the process. I had the same problem.
If you don't feel comfortable with the directions I typed, then shoot me a PM, I'll do it and make a vid for you.
hth...
mad
hth...
mad
"California Style"
Like the Hat said, it is easy to do anyway if you want the door panel off.
Just pry that bezel up and the wires will be long enough where you can unplug them. Then just snap the new one with a firm bump (after making sure the clips are all leading in) to get it in place without breaking them.
Mine had broken snaps from the factory which caused it to move around.
Yes, there are some tabs on the bottom of it that hold it in place that break off.
I would not order that whole piece, I think it is the whole switch assy, not just the oval ring.
Just get some good glue, man.
"California Style"
I guess it depends on how **** you are .
anonymous_1
07-01-2015 03:24 PM
Dynocon
03-04-2008 08:32 PM
Dave88LX
05-15-2006 08:44 AM
Palmetto_kid
01-10-2004 12:23 PM
