Does anyone know the control arm bolts torque spec?
I took off my lift and put the factory arms back on and torqued them to the other lift kits bolt spec but i have a knocking around sound coming from the frint end and looks like one of the bolts is moving around anyone have the torque spec for me?
No problem.
I re-read that page and the lower arm with the cam adjusting bolt should be tightened down to 160 ft-lbs. So...
Upper Arm: 120 ft-lbs
Lower Arm: 160 ft-lbs
PS - I recently uninstalled my 4" lift kit also. Truck rides smoother, handles better, and getting better mpg probably due to combination of being lower to ground and smaller tires.
Make sure the pitman arm nut is tightened to spec!!! Mine ended up losening up after a few miles when I first installed my kit.
itr.#1446
05-10-2008 08:30 PM
SilverSootXpres
10-08-2007 12:46 AM
GlennRMK
06-13-2006 11:48 PM
PWT05Dodge
05-26-2006 07:45 PM
