Do I need a 2" leveling kit?
I have 305/45/22 tires stock height. Well my tires are almost worn out because of certain habits of mine I need to lay off the burn outs for a little bit Anyways to the point do you think i need a leveling kit to clear 325/50/22 which in reality are 35/12.50/22 my rims have a 10 offset as a result stick out with my tires about an inch of the body line. And do you think it might rub the control arm even with a leveling kit?
As always any feedback is appreciated
David
David
What gears are you running you should fill in your sig. You might be ok with that offset I was runnin my H2s with 315s and no rubbing because of the increased offset of the H2s over stock wheels. Where a buddy of mine put 315s on stock wheels and rubbed control arms at full turn.
Your backspacing/offset is what is making it rub.
Raising it up wont help.
The further they stick out(in combination with a wider wheel), the more they will rub, either the control arms, back of the front bumper/rear of the fender wheel opening.
Hmmm so i'm probably going to rub if people are rubbing with 315's then for sure i will rub with 325's I honestly don't want to lift my truck at all, the most i was willing to do would be a leveling kit. I'm not sure if i would like the look of 285/55/22 or 285/50/22 because they won't be as wide but not by much. But i haven't found a tire that is 305/50/22 which would be nice.
Thanks guys
Thanks guys
PEAKSTRYDE
10-11-2007 04:20 PM
jrussell
18
12-31-2006 01:44 PM
06Cummins
18
11-21-2006 04:56 PM
MAJORCOMMOTION
10-15-2004 01:38 AM
kry226
07-26-2004 10:37 AM
