Dirty Cigarette Lighter?
Old 01-27-2009 | 05:39 PM
matthewthemanpa's Avatar
I just got a new mp3 player that I would like to power using the cigarette lighter since it will turn off automatically when I turn the truck off. The problem is it won't stay on. I have to twist & play with the plug to find the spot where it will stay on but as soon as I hit a bump it cuts off again. I know it is not the mp3 player because the same thing happens when I plug in a gps and they both work fine on the other 12v outlet. Could this be caused by a dirty outlet. I know the previous owner was a smoker and could have used it but it appears pretty clean to me. If I do need to clean it what would be the best thing to use?
Thanks,
Matthew
Old 01-27-2009 | 06:35 PM
w.tx iceman's Avatar
Thanks,
Matthew
It is probably wore out, the heat should keep everything burnt off of it when it is being used as a lighter. I guess you could pull it out and spray electrical cleaner in it.
Old 01-27-2009 | 06:38 PM
RTillery's Avatar
Mine does the same thing. I found if I take the accessory plug apart, there is a fuse in it. If I wipe both ends of the fuse and twist it into it's receptical, it seems to work better for some time(month or two). Then I have to do it again.
BigDan
0
09-03-2006 08:14 PM
CTD01
05-22-2006 10:13 PM
boarbuster
02-22-2006 12:09 AM
HL649
06-01-2005 12:14 AM
