difference between 2500 and SRW 3500
Here is a big diff. Insurence. It is cheaper to own a 3500 over a 2500 with State Farm insurence. Check it out with your insurence. That is one of the reasons I bought the 3500 over the 2500. I don't know why its cheaper, but it is.
Yeah pretty heavy. I was only going about 15 miles or I wouldn't have tried it with these tires. They are only rated at 3000lbs each.
Actually...this pic shows some of the sand removed (before the pallet was put on)....but I made another trip with the same load.............full cubic yard of sand and pallet of blocks.....56 blocks at 50lbs each = 2800lbs. And I was told a cubic yard of sand weighs about 2200lbs....but I don't know for certain. It was the heaviest load actually on the truck I have carried in the bed.
They were standard on SRW 3500 trucks 2003-06 (I think)....then they became an option...even on SRW 3500s.
Mechanically the only difference is overload springs to my knowledge.
Before I bought mine, I was researching on the Dodge website and the specs stated (at that time,) the following:
11.5 rear axle vs 10.5 on the 2500
Slightly larger rear brakes on the 3500
Slightly higher tow capacity for 3500 SRW
Turns out Dodge just put the same axles and brakes on both and only added overload leaf springs for the 3500. Also I think cab lights were no longer std. on 3500's after 2005.
Falstaff, The 10.5'' axle mentioned is for the "Hemi" powered 2500 trucks except for a few 03 models with the california emission SO engines.
Certainly from 04.5 on.........all "Cummins" powered Rams have 11.5'' rear AAM axles.......2500, srw 3500 and dually.
The tow capacity for the Dodge Cummins trucks have always been 21,000lbs for 3.73 gears and 23,000lbs. for 4.10s............minus the weight of your truck and it's cargo. (ex....mine has 3.73 gears and weighs in at 8500lbs or so with tools etc......so 21,000-8500 = 12,500lbs "tow capacity".......if I cared what Dodge Rated it at )
2500 has the 4/1 2600 in/lb springs, cab lights an option
3500 SRW has the 4/1 2600 in/lb springs and 1300 in/lb overloads. 03-05 cab lights standard, 06-curr cab lights an option
3500 DRW has the 3/1 2800 lb/in springs and 1300 in/lb overloads. cab lights required.
Axles are the same AAM 11.5", except rare 03 SO 47RE trucks have the AAM 10.5". AAM 11.5's are all rated for 10910 lbs. The SRW is narrower than the DRW, so the differences are hub spacers, axle shafts, and inner wheel bearings. Because the ratings and life expectancy are the same the larger inner wheel bearing on the DRW is to keep the life expectancy up from the increased stress from a wider heavier tire stance...
Brakes, frame, front axle, etc are all the same from a 2500 hemi thru a 3500 DRW CTD.
Location: Well I thought I lived in America, but its looking more like france every day.
My truck sags in the back with a 4 wheeler also. Its because of the level kit.
MikeRP
79
11-21-2016 10:19 PM
dragginlx
15
03-09-2007 11:32 AM
derherr65
13
01-25-2007 02:54 PM
chsaverline
15
05-03-2006 04:14 PM
westport
09-23-2003 07:15 AM
