Dash light bulb replacement help
Old 06-14-2010 | 04:40 PM
strippedthread1's Avatar
I have an 04 quad cab. The dashboard light behind the thermostat and fan ***** has burned out. What is the best/easiest way to get into it to replace the bulb?
Old 06-15-2010 | 01:11 AM
jhenson's Avatar
I used a paint stir stick to pop the trim off from around the area. Unscrew the bracket and use a small plain tip screwdriver to "untwist" the bad bulb and reverse the procedure for re-installation.
Old 06-15-2010 | 12:55 PM
Nate-03 D's Avatar
Do you know if the bulbs behind the instrument cluster (speedo, rpm, ect) use the same bulbs as behind the ac/heat controls?
Old 06-16-2010 | 03:59 AM
jhenson's Avatar
Yes, the bulbs are all the same. When I got mine they were still dealer only. Maybe someone has info on the possibility of aftermarket, however I believe I only paid like 4 bucks a piece for mine from the ***********.
NoSparkplugs
17
05-17-2009 11:36 PM
robert78.5
09-28-2007 11:23 PM
gus's 03
07-10-2006 12:13 PM
rockittboy
06-05-2006 09:28 PM
