Cruise Control quit working???
All of a sudden, no cruise. THe light on the dash comes on, but I can't set or engage anything. ANy ideas? This is w/ the Smarty on and off, doesn't matter.
Not only the vacuum pump the vacuum lines as well.
Dodge used some hard plastic as vacuum lines and mine was rubbing a piece of steel on a bracket.
The good news is if it is a line you can fix it in the autozone parking lot!
My cruise control was working intermittently and I checked the codes and it gave a high voltage indication on cruise control switch or something like that. Replaced the left cruise switch on the steering wheel and it's fixed for $28. Turn the key on and off 3 times quickly and the codes will display in the odometer on an 03.
Don't feel bad, my Dakota's cruise control cuts in and out going down the road. I had the dealership replace the controls, but it still does it. I have given up on it because I do not drive it very far to work anyway, and that is the only reason it is still around plus the wife can't drive a stick. If you do come up with a solution let us know, it be the same reason for mine.
SO my question still is, what does the vacuum have to do w/ the cruise control? My dash light comes on when I turn the cruise to on, but I can't set anything. Does anyone know anything about this cruise control system?????
I have a 2004, hopefully this is the same for a 2003. The vacuum pump is energized any time the key is on, even if the engine has not been started. There must be a vacuum sensing switch somewhere because the vacuum pump does not run continuous but cycles. Something is telling it when additional vacuum is needed. Disconnect the wires feeding the vacuum pump and jump 12 volts straight from the battery to see if pump is good.
