color of oil
color of oil
i remeber the rotella t going in was brown now when i check it is it black. it does NOT smell like diesel. is this normal, i am just making sure.
Usually when an injector fails it is a catastrophic event, filling the crankcase with diesel quite rapidly. If you do a search for recent posts you will see that in 5-10 miles you will go thru 10 or more gallons of diesel. In my case it 11 miles used 12 gallons of fuel so it will be obvious. I had no symptoms other than the full crankcase all at once.
Speaking of black oil,
I just did the second oil change on my 07', (first at 2500, second at 8000) and it was the blackest oil I have ever seen!!
I filled the crankcase with 3 gallons of clean Rotella T and fired it up to circulate the fresh oil until I saw oil pressure biuld.
I then moved on to the fuel filter. After the fuel filter was done I checked the oil level (figuring it would have settled out by now) and was surprised to see the new oil was already black!! I can't believe the residual oil in the motor was black enough to contaminate 3 gallons of fresh. I guess I should tighten up my oil change intervals.
USMC64-70
14
10-24-2004 09:41 AM
