Check your AC line from pump to beside the radiator.
My AC suction and discharge line got up against the fan shroud just barely and the constant rubbing opened a hole up. Its the line that comes out the back of the AC pump with a small sensor down at that end. It works its way up between the radiator and air box. Then comes around to the condensor in front of the radiator attaching right behind the black plastic wind screen. Might want to check it on your truck because there were over 200 on backorder. Just could be a more common problem than we know.
Mine had melted from the black canister to where it goes to the condensor. Where the aluminum line is a 90* angle. I am going to get the aluminum TEG welded. **** twins
jesussaves
12-23-2011 11:31 PM
mullishacrew
12-19-2007 07:13 PM
NoSparkplugs
10-24-2005 10:15 PM
