Can Someone Do A Guages/bulb Check For Me?
#34
DTR Detective
06 here...
No "Service 4WD" light
No "Runflat" light
No "Water in fuel" light
No "Auto 4WD" light
and one other I can't make out...
Codes in order:
5 11.6
. 281
C 447
P.S. Can anyone confirm 10 engine light flashes after the end of engine codes after it says "DONE" it flashes 10 times then stays on?
No "Runflat" light
No "Auto 4WD" light
Codes in order:
5 11.6
. 281
C 447
#36
DTR Detective
Runflat tires...they have an indicator to let you know when your tires are low on pressure.
It looks like a flat tire with an arrow or lightning bolt in it on your dash, it's in the area in the middle above and to the left of the Water in Fuel, IIRC?
#42
Check this out.
It was bugging me, so I just unplugged the connector and shorted the two wires on the connector with a small piece of wire, turned on the key and it came on. At least I know the lamp is working.
I read in the service manual and as far as I can tell it is supposed to come on when you turn the key on initially and when yoy do the odometer button trick. I don't know why mine or any body else with an 06 dosent but thats as far as I can get.
craftybigdog
02-04-2011 09:27 AM
robert78.5
09-28-2007 10:23 PM
zehnmm
07-03-2007 10:11 AM
