Cabin Air Flow no Defroster ai flow or Dash level
Old 01-11-2008, 05:59 AM
ralphyboy's Avatar
I'm getting air flow at the floor but I cannot get air flow through the dash and defroster. I can hear some movement as I rotate the dial.
2005 2500 Diesel. Is there a vac system that operates the direction of flow?
Old 01-11-2008, 11:18 AM
rockjeep's Avatar
Welcome to the broken defrost door club. You will have to have it fixed. If under warranty the dealer will do it for you, but if not. You will have to pull the whole dash to get to the heater and fix it.
Old 01-11-2008, 12:15 PM
JGP, JR.'s Avatar
Yep...............mine broke at about 20,000 miles. Luckily under warranty and was replaced by dealer. Good luck on getting it fixed!!!
Old 01-13-2008, 10:03 AM
ralphyboy's Avatar
Thanks - for replys I'm a 2005 Purchases July 2005 with 32K miles. I hope this is a warranted item.
Old 01-14-2008, 10:30 AM
Jonesey's Avatar
It is covered under the 3 year 36k bumper to bumper warranty.
Old 01-14-2008, 05:24 PM
JWillms81's Avatar
What if your not under warranty anymore, anyone have a how to on what you need to fix and how? I checked my recirc door and it still works good but my control on where it come out(vent, floor, mixed, deforst) has a mind of its own and will work when it wants.
Thanks
JW
Old 01-14-2008, 05:59 PM
Rocky's Avatar
Not sure if this will fix your problem.
Great write-up by ratlratl, page 2 has step by step.
https://www.dieseltruckresource.com/...ighlight=blend
Old 01-14-2008, 09:41 PM
sweeney186's Avatar
Thanks
JW
Your going to need the defrost plate-chry#5086718aa.Tsb 24-004-02 covers replacement procedure-a little more difficult that a recirc housing,but dooable
Old 01-14-2008, 11:23 PM
JWillms81's Avatar
Thanks guys
Rocky yeah I read ratlratls post and checked my recirc door and its working great, I think my problem is diffrent then what there talking about on that post.
Sweeney, thanks for the part number and TSB, I looked at Dogeram.info at there tsb section and couldnt find the 24-004-02 that your talking about. Would you happent to have a link to something I could read or print to help my on the install.
Thanks
JW
Old 01-15-2008, 12:21 PM
sweeney186's Avatar
The tsb is for 02 models only-but its the same part for all dr 02-08 & I'd post a link-but its from mamma chry-you have to have a registered user id to access.Just follow the instructions for a recirc housing-which will get the dash back & the plate is in the middle & up top-no case removal necc.
Old 01-17-2008, 08:35 PM
MMMmmmm.... Grits!!
ratlratl's Avatar
Here is the printable file......
File Type: pdf
fade94
04-21-2010 07:10 AM
NoSparkplugs
17
05-17-2009 10:36 PM
Nate-03 D
10-08-2007 06:53 PM
TonyB
04-07-2006 06:48 PM
andyr354
01-10-2005 01:33 PM
Quick Reply: Cabin Air Flow no Defroster ai flow or Dash level
